Difference between Ctrl + V and CTRL + V + Shift
Jan 16, 2024
1 min read
The famous Ctrl + V key combination is used to paste content copied from the clipboard. This also includes the formatting of copied text. For example, if you copy bold text, the pasted text will also be bold.
If you wish to copy text without formatting, you should know that the key combination Ctrl + V + Shift can be used to paste the copied content without formatting. In other words, the pasted text will have the same font and size as the surrounding text, without any additional formatting.
Source :
