SketchBook Pro is a digital drawing and painting application created by Autodesk
Aug 6, 2023
2 min read
SketchBook Pro is a digital drawing and painting application created by Autodesk. It is available for Windows, Mac, iOS and Android devices. It can be used to create a variety of creative content, including sketches, illustrations, paintings and animations.
SketchBook Pro
SketchBook Pro comes with a wide range of features, including :
  • An intuitive, easy-to-use user interface
  • A wide choice of brushes and colors
  • Advanced drawing and painting tools
  • Layer and mask functionalities
  • Auto-save function
  • Ability to export your creations in JPG, PNG, PSD or BMP format
SketchBook Pro is an excellent choice for artists of all levels, from beginners to professionals. Compatible with a wide range of devices.
SketchBook Pro
Here, in detail, are some of the most popular features of SketchBook Pro :
  • Brushes : SketchBook Pro offers a wide range of brushes, including traditional brushes such as pencils, pens and brushes, as well as more modern digital brushes such as watercolor and airbrushes.
  • Colors : SketchBook Pro offers a wide range of colors, including RGB, CMYK and HSL. You can also create your own custom colors.
  • Advanced drawing and painting tools : SketchBook Pro offers a variety of advanced drawing and painting tools, including selection tools, layer tools and mask tools. These tools let you create complex, detailed illustrations.
  • Auto-save function : SketchBook Pro automatically saves your work every few minutes, so you never lose track of your progress.
  • File export : SketchBook Pro lets you export your creations in JPG, PNG, PSD or BMP format. This lets you share your work with others or print it out.
If you're looking for a powerful and versatile digital drawing and painting tool, SketchBook Pro is an excellent option.
Also available for iOS and Android !
Language : English, French
Price: ~ 20 Euros
OS : Windows, macOS
